Respuesta: Comunicaciones remotas
A few of my customers have changed from Sat to mobile network using an external antenna & 3G router, They get an average of about 2m, sometimes up to 6m, Way better than Sat (And Telefonica in most cases If you can get land line)
Have a good one
Tim
Algunos de mis clientes han cambiado de Sat a la red móvil usando un & de la antena externa; el ranurador 3G, consiguen un promedio de los cerca de 2m, a veces los hasta 6m, manera mejor que Sat (y Telefonica en la mayoría de los casos si usted puede conseguir la línea de la tierra)
Tenga buen Tim
Buenas, lo primero gracias. Entonces me dices que la tecnología 3G es mejor tecnología que satélite. ¿Ahí algún router 3G en el mercado que me puedas recomendarme? ¿que velocidades de comunicación suelen rondar la técnologia 3G?
Well, first thanks. Then I say that 3G technology is better satellite technology. "That a 3G router on the market that you recommend? What communication speeds average around 3G?
A greeting.
I have not used it myself, but below is a mail from my client, He has also recommended to other clients who report very good results.
I do have a HTC wildfire mobile phone that does the same (provide a wifi hotspot) No ideal for you, but makes a great "test" tool to see if you could do better with mobile net,
What are type of data you trying to send ? ?
The Serviman service was so appalling, I’d be happy to see all of their customers switch.
Here are the details of the router and antenna that we have.
Antenna – SMP-918-9
[email protected] ask for Stuart
Router – Teltonika RUT-104 -
[email protected] ask for Andre
They can set up the router for the 3g network that you will use, after that it is pretty much ready to go. Make sure you turn off the PIN on the SIM card which you can do by putting it into your mobile and using the menu there. Also make sure you get the correct extension cable for the antenna. They will know what to send, and they know each other so can be emailed at the same time.
No lo he utilizado mismo, sino abajo soy un correo de mi cliente, él también ha recomendado a otros clientes que divulgan resultados muy buenos. Tengo un teléfono móvil del reguero de pólvora de HTC que no haga el mismo (proporcione apuroses del wifi) ninguÌn ideal para usted, pero hago un gran " test" herramienta para ver si usted podría hacer mejor con la red móvil, ¿Cuáles son tipo de datos usted que intenta enviar? ¿? [COTIZACIÓN] el servicio de Serviman era así que aterrando, me placería ver todo su interruptor de los clientes. Aquí está algo que envié a un amigo recientemente. Aquí están los detalles del ranurador y de la antena que tenemos. Antena - SMP-918-9 el sales@ connextechnologies.co.uk pide Estuardo El ranurador - Teltonika RUT-104 - support@ nucleusnetworks.co.uk pide Andre Pueden fijar el ranurador para 3g la red que usted utilizará, después de que que es bonita alista mucho para ir. Cerciórese de le para apagar el PIN en la tarjeta de SIM que usted puede hacer poniéndola en su móvil y usando el menú allí. También cerciórese de le para conseguir el cable de extensión correcto para la antena. Conocerán qué enviar, y a les se conocen así que pueden ser enviados por correo electrónico al mismo tiempo. [/QUOTE
Tim
Just to add, the mail is about a year old, the suggested components are high quality and designed for poor signal, depending on signal strength and you requirements, It could be done for a lot less €, Vodafone: Acceso a Internet Módem USB K3765 + Base Wifi R101
el ust a agregar, el correo es alrededor de un año, los componentes sugeridos es alta calidad y diseñado para la señal pobre, dependiendo de fuerza de señal y de usted los requisitos, podría ser hecho para mucho menos €,
Have a good one
Tim
Buenas.
Los datos que estamos tratando son datos en DNP3, porque en nuestras oficinas tenemos un Scada. Con los datos Modbus TCP, cuando se pierden las comunicaciones se pierden los datos y decidimos ir con esta tecnología.
Tendré en cuenta este contacto y gracias de antemano.
Good.
The data we are trying DNP3 data, because our offices have a Scada. With Modbus TCP data, when communications are lost data is lost and decided to go with this technology.
I will consider this contact and thanks in advance.
Nosotros con los modem Huawei B220 de orange tenemos un monton de huertas monitorizadas, y dan muy muy pocos problemas
Buenos días.
Tengo unas preguntas: ¿Que precio rondan estos equipos? ¿Que tarifas tenéis para España con Orange?¿La configuración del equipo es fácil?
Un saludo y gracias.
El precio y las tarifas las hemos negociado por el volumen que tenemos, no tengo ni idea de que precio tienen pero todo es preguntar. En cuanto a la configuracion, se hace toda via web y no lleva mas de diez minutos.
Yo también tengo un Huawei E220 con antena exterior. Mi problema es que no tengo cobertura 3G, solo GPRS (max. 60kbs). Precio 5€+IVA cada mes con Movistar (la única que da cobertura) tarifa de datos para movil, como no usas la voz, solo pagas los datos...y al cabo de un par de meses, les dices que quieres dar de baja el servicio de datos de la linea, entonces, antes de perderte, te ofrecen una rebaja del 50%, la aceptas a regañadientes y ya tienes tarifa de 5€/mes ;-)
Justamente, yo pensaba poner conexión via satélite, ¿alguien me puede aportar sus experiencias?
Antes de decidirte por modem 3G debes comprobar si tienes cobertura. Otra posible opción es usar radio-modems, algo más caros pero te aseguran un buen punto a punto en distancias relativamente cortas (< 20 km.).
Y si tienes visión directa a un router wifi normal, una antena direccional de alta ganancia también es solución barata (hasta 5 km.)
En campo y sitios alejados no suele haber muy buena cobertura 3G, nosotros hemos cambiado todas nuestras plantas que teníamos con satélite a wimax, por Castilla y León la cobertura de Iberbanda es excelente y por poco dinero tenemos 1Mb simétrico, va como un tiro, cámaras incluidas.
El problema de wimax es que tiene que haber conexión casi directa, pero lo hemos solventado poniendo la antena más alta, en un sitio a 18 m. de altura, compensa.
Tambien he visto un campo en el que lo solventaban con Zigbee, que al parecer te da hasta 20Km de alcance sin necesidad de tener vision directa entre los puntos, pero ahi no tengo experiencia directa.
Yo tambien te recomendara que busques un proveeder de Wi-max, por precio y prestaciones es de lo mejorcito.
Y para las comunicacinoes entre ct's con wifi, que por 50 euros que vale una antena, mas el equipo central (unos 900€) te olvidas de redes 485 y problemas con los ratones.
