Resultados 1 al 7 de 7
    sep 2007
    TIERRA
    Predeterminado LAMPARAS DE LED
    hola camaradas.
    que opiniáis de las lámparas de led para instalaciones fotovoltaicas; las habéis utilizado?
    y en farolas??
    que opinais de esto:
    LED Lamp scalable / configurable Lamp: Three different elements included:
    a. Scalable LED segment: we are analazing two different solutions, one, that complies perfectly the 10W stepping, and a second one, which has slight biger steps. The key point here is that to be cost effective, the solution might be already designed, otherwise, the cost is going to be so high.
    b. LED drivers (current supply), required to be able to give proper current from the battery to the LED segments as required, depending on the battery and the LED segments, might be required to step-up voltage from 12V up to more than 30 volts. Those elements are LED Segment solution dependant, and also scalable solution.
    c. Lamp head, the element that is going to host the LED elements and LED drivers. The same way, we are analyzing two different solutions based on modular scalable segments, that might be configured on demand.
    saludos camaradas
    A Mountain man is a lonely man and he leaves a life behind, he ought to have been different what you often times will find, his story doesn´t always go, the way you have been mind, Jeremiah story was unkind.........
    Avatar de 6volts
    6volts está desconectado Forero
    jun 2009
    fraggel rock
    Predeterminado Respuesta: LAMPARAS DE LED
    exelente. ¿que tipo de farolas?
    sep 2007
    TIERRA
    pues la típicas farolas solares que llevan acoplado un modulo!
    sep 2007
    TIERRA
    pero vamos que olvidate de los de las farolas, lo que me interesa es si alguien tienen experiencia con la tecnología de lámparas de leds
    Avatar de 6volts
    jun 2009
    fraggel rock
    hombre no tene mucha ciencia ja ay en le mercado diversa bombillas de leds.
    a 12 e 220 de tono blanco frio e de tono calido,dependendo del sitio que las pongas,de 1w ou 3w,tipo halogeno para 12v o rosca para 220v.
    en fraggel rock mi casa solo hay leds hace uns años e bien contento tengo unas lamparas caseras "hade made" de 12v pero a 10v funcionan e como maximo 28v la e provado a 36v pero se ponen muy calentes, e com un comutador que me reduce 1w de consumo.
    no se se te sirve de mucho pero mi consejo es que proves en algun sitio las comerciales valen uns 10€ las de 1w e las de 3w uns 20€ + o -.
    un saludo
    sep 2007
    TIERRA
    gracias sixvolts!
    los principales puntos a la hora de elegir un sistema de iluminación, deberán ser que :
    * que ofrezca el grado de iluminación acorde a las necesidades
    * que la tecnología utilizada tenga un buen grado de disipación del calor (con lo cual quedan descartadas los sistemas de incandescencia).
    * que sean de baja potencia de consumo
    a alguien se le ocurre algo más......
    saludos camaradas!
    Una iluminación LED no debe calentarse apenas. Si lo hace o son malos o están diseñados con el culo y a una tensión inadecuada que los matarán con el tiempo.
