Chris Busby [visiting professor at the University of Ulster’s school of biomedical sciences and scientific secretary of the European Committee on Radiation Risk, a think-tank -
Bloomberg]: There’s a very, very high level of contamination even as far south as Tokyo. For example, we found one sample in Tokyo that had levels of radioactivity higher than levels inside the Chernobyl exclusion zone. a Very serious matter.
Governor ‘very concerned’ as radioactive hydrogen leaks from nuclear power plant in Connecticut, Daily Mail, August 18, 2011:
A radioactive form of hydrogen has leaked from a U.S nuclear plant into soil and groundwater has reached the nearby Connecticut River, according to health officials.
State Department of Health Commissioner Harry Chen said water samples from the shoreline near the Vermont Yankee nuclear plant last month tested positive for small amounts of tritium, a radioactive isotope of hydrogen which has been linked to cancer when ingested in large amounts.
Governor Peter Shumlin wants more wells to pull contaminated water from the ground on the Vermont Yankee site. He says he is ‘very concerned’.
Entergy’s Response In response to claims of a leak, Vermont Yankee said in a statement: ‘We are aware that the Vermont Department of Health may have detected strontium-90 in some fish from the Connecticut River.
‘There is absolutely no evidence to suggest that Vermont Yankee is the source for the strontium-90. We have 31 monitoring wells on site that are tested regularly. No groundwater sample from any well at Vermont Yankee has ever indicated the presence of strontium-90, or any other isotope other than tritium.
‘We do not know why the Governor would suggest Vermont Yankee is the source, but there is no factual basis for that suggestion.’
Report: Workers say ground under Fukushima plant is cracking and radioactive steam is coming up — Melted core may be moving out of building (VIDEO)
August 17th, 2011 at 11:34 AM
Host: “Workers at Japan’s Fukushima plant say the ground underneath the facility is cracking and radioactive steam is escaping through the cracks” [...]
Dr. Robert Jacobs, Hiroshima Peace Institute: “It’s a very serious and alarming development because this started to happen specifically after two large earthquakes in the last few weeks, there was a 6.4 on the 31 of July 31 and a 6.0 on August 12″ [...]
“It’s an indication that radioactive material is moving under the ground” [...]
“When you have a fragile structure that’s already suffered a great deal of damage and when you have continual aftershocks at the level of six-point, or there’s been some even higher, what we have now is we have the radioactive core that has melted down into the basement, into the bottom of the containment vessel of these reactors, and if the radiation level is going down, where it’s been monitored inside the buildings, and if the water pressure is going down, and the temperature is going down, it’s not that the radiation is just suddenly going away, it means that the radioactive material, the melted core, is simply moving further away from where it’s been measured. And it may have — as a result of these aftershocks — be moving down out of the building itself.” [....]
http://enenews.com/wp-content/plugin.../lyte/play.pnghttp://enenews.com/wp-content/plugin...ntrols-425.png Cracked Fukushima: Radioactive steam escapes danger zone
Breaking News: #Fukushima splashing steam from the cracks in the ground, Fukushima Diary by Mochizuki, August 15, 2011:
In early August, an actual Fukushima worker emailed to his friend “
A lot of the cracks came up in the ground,massive steam is coming up from there.It’s too smoggy here,can’t see a thing.It seems like nuclear reaction is happening underground.
Now we are evacuating.Watch out for the direction of wind.”
Ese abundante vapor lo confirman vídeos de las cámaras web que no me ha dado tiempo a poner.
