Resultados 1 al 2 de 2
    Mike48t está desconectado Forero Junior
    ene 2021
    espana
    Predeterminado Bronpi Pincesa, Pellets overfeeding
    Hi and Good Day, after many years of owning and being very satisfied with my Bronpi Princesa 12Kw Stove it seems to have developed a fault,
    The system starts up normally and works thruogh the process heating the house ok,
    I current have temp set to 23C, and normally the Auger for pellet feed is intermittent based on demand, but over the last two days it has about every 10 mins or so started to feed continuously, this persists until it seems to reach the temperature of 27C on the dispay and then the display says Fire wait and after a minute or two the system reverts back to normal, ( it would seem as though it has reached a temperature threshold E 27C when on continuous feed and then the unit shuts down and waits until a normal condition returns and starts to work correctly,
    it is also noticed that the flame goes Log and smokes the glass during this period,
    I have physically checked the temp probe at back of fire, and it seems secure and not damaged etc , All chimneys and flues have been cleaned, and the Firebox is cleaned daily and flues checked, pellets are same as usualy ( TU Pellets) which I have used for a number of years with no problems,
    any ideas of items to check please, thanks in advance,
    Hola y buen día, después de muchos años de poseer y estar muy satisfecho con mi Bronpi Princesa 12Kw Stove parece haber desarrollado una falla, el sistema se inicia normalmente y funciona thruogh el proceso de calentamiento de la casa ok, tengo actual temp set a 23C, y normalmente el Auger para alimentación de pellets es intermitente en función de la demanda, pero durante los últimos dos días ha comenzado a alimentar continuamente cada 10 minutos más o menos, esto persiste hasta que parece alcanzar la temperatura de 27C en el dispay y luego la pantalla dice Fuego espera y después de un minuto o dos el sistema vuelve a la normalidad, ( parece que ha alcanzado un umbral de temperatura E 27C cuando se alimenta continuamente y luego la unidad se apaga y espera hasta que una condición normal vuelve a funcionar correctamente, también se observ también se observa que la llama va Log y fuma el vidrio durante este período, he comprobado físicamente la sonda de temperatura en la parte posterior del fuego, y parece seguro y no dañado etc, Todas las chimeneas y los conductos han sido limpiados, y la Firebox se limpia diariamente y se comprueban los conductos, pellets son los mismos que usualy ( TU Pellets) que he utilizado durante un número de años sin problemas, cualquier ideas de artículos para comprobar por favor, gracias de antemano,a
    Avatar de SAT.Bronpi
    sep 2015
    Lucena, Córdoba
    Predeterminado Re: Bronpi Pincesa, Pellets overfeeding
    Good Morning,
    When it comes to your review I must inform you that it has not sense a priori the auger motor performance that you explain, unless someone has changed the auger motor parameters setting. The geared motor in all powers has both a rest time and a work time, without the rest time as you explained before it’s impossible that the stove works as it will show an error. The geared motor feed cannot be continuous, you would see on the screen the alarm b.
    Regards.
    Joaquín (S.A.T. Bronpi)
    www.bronpi.com
